Rawbrown
- Encinitas, CA
$650 for a C8.25 detroit? ouch...
Powertrax is the company that makes both the lockright and the no-slip.
the lockright will ratchet as it unlocks to allow the outside tire to rotate faster. the no-slip has whats called an active spacer that keeps the engagement teeth appart while your going around a turn, preventing the ratcheting. no-slip is a glorified, upgraded, softer spoken, gentler with the ladies big brother to the lockright. the aussie locker and ez locker are the same design as the lockright, they are just a little bit more PITA than the lockright to install and remove. the spring slots arn't big enough.
The limited slip is a carrier in itself.
Yes a rear locker is a great starting point.
