- MilkyWay Galaxy
The head gasket SEALER solution has a higher concentration of silicates than the old formula green antifreeze solution uses, and it has the fibers. It will seal larger holes and leaks and do it faster. Either of the leak stops (heavy duty, or standard duty) will need heat, and pressure, and time to seal up the leak.Now, that product you linked is a head gasket repair solution... I would assume that sees a lot higher temps & pressures than a heater core does, initially needing high temp when applied, to "bake" it on, so to speak...
Would using a lighter duty sealer be less prone to building up in unwanted areas, like within the block?.. "New style coolants", you mean those orange ones?
Most of the antifreeze on the market today does not have the sodium silicate in the formulas now (not sure why, as it is extremely environmentally safe?). So make sure you get antifreeze that actually lists sodium silicate on the antifreeze bottle label as an ingredient!!!
The silicate is chemically a liquid glass, and turns into a concrete/sand like solid when it dries in the hole. The fibers catch on the hole, and give the glass/concrete seal structural strength (think fiber composite). It dries by being hot and seeing ambient air on the outside of the leak. New cars for 80 years had the fiber pellets added to the radiators on all new cars up until 1996 that I know of. After 1996, I don't know if they changed that.
Just because the antifreeze is green, does not mean it is an old silicate containing formula!!!
The light duty sealers are used year round, for sealing and to seal if and as a tiny leak develops. New car companies use (used) the fiber sealer pellets and silicate in the antifreeze to get them past the warranty periods for at least 80 years!!!
The heavy duty sealer can not be used year round. It is used for 1-2 hours to seal BIG leaks, then drained and replaced with usual antifreeze mix, and fibers.
Near as I can tell the radiators and heater cores made now days, use such narrow tube openings and have such thin walls, they plug up in 3-4 years no matter what you use.
