- MilkyWay Galaxy
Correction, I was talking about the cleaning the outside walls of the lifters and the block wall originally, not the guts of the lifter. I was assuming the guts of the lifter was OK< and not collapsed.
The video later gave us ideas about the need to clean inside as well.
But I have some doubts about whether or not it would work on the inside of the lifters. Additive to the bulk oil, pumped by the oil pump might be the best approach there. You have the flow force to help. But the out wall is another story. It is where I think the rotation stops due to sticky varnish-carbon and there is no high pressure oil there to wash it out?
Re-read EcoMike's 2nd post. He was talking about removing the valve cover, removing the push rods, and spraying PB down the openings to the lifters, then cranking the motor to work it into the lifters, then letting it soak overnight. Then draining the oil. All I'm saying is pour some oil down those same openings to help get the PB out of the lifters, before reinstalling the push rods and the cover. Make sense?
No need to get so excited ... we're just having a little conversation here.
