Talk about back pressure and abscense of bak pressure. Two vehicles come to mind. I had a 1st generation Dodge Intrepid with a 3.3 Liter engine. My brother had the Dodge Caravan also with the 3.3 Liter engine. The most noticable thing looking at both engines were that the intake and exhaust were different. Both had the same basic engine. Both tuned to run at different RPM's. While the Caravan would take off screaming with 8 passengers, the Intrepid would struggle too get going. At higher RPM's, the Intrepid would run rings around the Caravan full or empty. Both engines had the air delivery and removal tuned for a different purpose, one for plenty of low end grunt while the other needed a running start to build power. Both vehicles had close the same top speed eventually.
On my 1994 XJ, I changed the OEM manifold to a semi performance/performanance depends on how one looks at it. It was a much free-er flowing exhaust (at least it sounded like it was). My 0 to 40 (ish) MPH sufferred. I could no longer steal a jump out of a stop turning right if there was a chance another vehicle was coming. It just did not get up to RPM thus MPH as quickly as it did with the OEM manifold. From 2,000 RPM up, it went like a bat out of hell. Highway cruise 2,000 RPM up was noticiably improved. Again, the only thing changed was the manifold. Was it because of more back pressure, ........or less back pressure?
