Andy in Pa.
NAXJA Member #180
- Downingtown, Pa.
Right now I have the EP-26 relay plugged in, and they operate the turn signals just fine at a normal rate. They DO NOT operate the hazards at all though. The EP-26 relay does not have the pin for the hazards. I still have to tie the wires together on the back of the relay panel, like Jeepin Jason did.
So Farmermatt, let me get this straight...you took out the factory relay (which should be an EP-27 or equivalent) and put in an EP-27 (which is actually the Tridon/Stant part number) that you got from NAPA (Autozone, Pep Boys, Advance have also) and your turn signals and hazards blink normally? Hmmm...maybe the factory relay is different somehow? I might have to try it.
Andy
Andy
