LED Flush Mount Spot Pattern Clearance!
JADFab
[size=+1]Looking for some additional light on or off-road?
I've got an overstock amount of Flush Mount LED Pods in the spot pattern that could use some new homes!
You can see the Flush Mount LED Pods in the spot pattern in the lower left corner of the following picture:
These have seemingly limitless uses: Bumpers, Reverse Lights, Roof Lights, Rock Lights, Trailer Lights, Truck Box Lights, Boat Lights, heck they've even been used as home security lights!
Clearance Price : $50 per pair, which includes a COMPLETE plug and play harness so there no worry about messy wiring!
Shipping is $15 anywhere in the lower 48 for one pair. Buy two pairs, shipping is $10, buy three or more and shipping is FREE!
These are 3x2, 18W LED Light Pods with CREE LED's (not Epistars). These lights are small but put out an enormous amount of quality light for their size. These are not the lower quality eBay/Amazon lights, and I stand behind them.
I have both spot and flood beam available.
Light Specs:
- 1800 Lumens
- Operating Voltage: 10 - 30 DC
- IP68 Waterproof Rating
- Poly Carbonate Lens
Dimensions:
Flush Mounts:
- Face: 4-3/4" W x 3-1/2" T
- Flush Mount Part of Pod Body: 3" T x 3-1/4" W x 2-7/8" D
As mentioned above, the lights come with a COMPLETE dual plug & play harness. This means each harness has two plugs for each light in the pair.
What do the harnesses have?:
- Quality Deutsch Weatherproof Connectors
- On/Off Switch
- Large Blade Fuse and Fuse Holder
- Automotive Relay
- Ring Terminals for Battery Post Connection
It doesn't get much, if any, easier to get your light running than it does with this harness. Simply connect the power and ground terminals, connect to your lights, and mount the switch!
[/size]
