kootenayXJ
- west kootenays BC
Sorry to beat a dead horse but I've searched and unfortunately, the more I read, the more confused I get. Please try to be patient as I ask some (probably) stupid questions and try to regain some sanity!
I just finished doing a 3103-CV hack-n-tap SYE on my 2000 XJ sport, 3" lift, 5spd with 8.25 rear end. The entire thing went really well and I used a front driveshaft from an '89 Dodge Dakota as it is longer than the usual junkyard donor (XJ front shaft) that most people use. My measurements worked out perfectly and the slip yoke on the donor shaft sits in the middle of its travel allowing plenty of room under compression and extension.
My only problem, is of course that I need to install shims under the leafs to tilt the pinion up and be 2-3 degrees under the driveshaft angle.
I'm a bit confused regarding which shims to use now - I'm certain that I've measured the driveshaft angle and pinion angle correctly, and the numbers I get show a 10 degree difference between the two. Subtract 2 degrees for the pinion to rise under power and this leaves me with an 8 degree difference to make up with shims.
Most people say they use a 3 degree shim for this height of lift after a SYE but it's looking like I will need around 8 degrees. This seems way off to me. Can someone verify this please, am I missing something?
Here's a photo I found on - in my case, the difference between the two yellow lines is 10 degrees.
