KY: ISO short block
There was an entire XJ here in Terre Haute that had been hit in the front (not awful) for $400. 160k on it I believe.
It's a girl that works with my wife. I can see if it's still available if you'd like.
I'm in Dayton Ohio and have one. Needs rod bearings
I have one that you can come pull out of a 97.
you can hear it run before you pull it.
Hell, if you come take the whole thing I'll make you a deal as long as I get my trans/t-case out of it and the clutch bits.
sorry guys, just dont have the time to transport all my tools and pull a motor. Rather looking for something already sitting out.
You might check with this guy in Zionsville,he might have a short block laying around you never know? I bought some parts off of him before , good dude.
https://indianapolis.craigslist.org/ptd/5443480491.html
I would be very careful that guy. This must be his 'new' business. He used to run a business called Direct Engine Source in Franklin, IN. The number in that ad is the same as the number for Direct Engine Source, which is no longer a business. There were issues.
mac 'just FYI' gyvr
Also I have a good rebuild-able block sitting in my garage out of a 97 XJ. The number 2 piston started coming apart. You'd have to do a rebuild on the motor, but it's a good block.
I'm assuming you are looking for something that is running, but just in case.
mac 'PM me if interested' gyvr
mac 'just FYI' gyvr
Interesting...I just came across him on CL when I was looking for an intake. Sucks if it's the same guy he seemed pretty cool.He ran his shop out of his garage, had a crapload of machining equipment. Thanks for heads up.
Yeah he used to have a shop...
Long story but I would be very careful with dealing with him.
You don't close up a nice big shop and run it out of your garage for no reason.
mac 'nice enough to keep taking money' gyvr
I've got my wrecked xj. Need P/s pulley and valve cover but it ran before I rolled and while I was on my side. Then I turned it off. It's at my shop. I could pull it.
Sent from my MotoG3 using Tapatalk
