- Rainy side of Washington
Yup. Same TRE taper. You will need the 99.5-01 XJ unit bearings, all the brake swap stuff, the WJ balljoint(s) (lower required, upper only required if yours is worn out anyways), and the JKS weld-on unit bearing spacers. Steering can be swapped at a later time, or not at all.
