i drilled out my knuckles to 5/8, to use heim joints for over the knuckle setup. i wanna go back, idk if you can buy tapper inserts or not?? if not does anyone have a spare knuckle for a driver side D30.
thanks, i think a while back you were gonna help me out but the mail lost the bolt that you sent me. right now im trying to see if i can get one local, if not ill hit you up. on a side note i was wondering if anyone else has had problems with otk setup? i have rustys piece of crap and everytime i turn to the left the tie rod hits the right coil pad?? plus i dont like how the drag link mounts to the right side knuckle. i was thinking of buying teraflex knuckle and get an new/used driver side knuckle and go back to tie rod ends. http://www.teraflex.biz/products/teraflex/cherokee-xj-84-01/high-steer-knuckle.html...
If you decide to weld the inserts, a 55% nickle rod works well when welding cast with a stick welder. You really only need to tack it in, Goferit recommends in 3 spots around the insert flange. I just put one in yesterday.
