Ok, so I got a Kenwood KDC-MPV 8025 from my fiance's brother in-law. I wired up the Yellow to the Yellow, Red to the factory purple/white-stripe, and black to the black ground stock wire. Turn on the Jeep, the unit turns on, the flip down deck flips out about half way then goes back to it's semi closed mode... I can look down into the little slit and see that the unit is indeed on... but doesn't stay open to use the controls and get out of demo mode. Anyone a car audio guru or know much about Jeep stereo wiring at all? I'm pretty sure it's hooked up right... unless i'm not getting a good enough connection on the wires. Is there another wire in the Kenwood harness that needs to be wired up for it to work properly? If so.. which? Thanks! I need to figure this out before Friday... getting married and we need tunes while we drive up to where we're going on our honeymoon!
