I don't see how this mod can force you into first and looks pretty pointless. For the first diagram: With the switch in C, the TCU is powered and everything is normal. In B, you've killed power to the TCU and you shift as described before (1-2) gives you first, (3) gives you 3rd, (D) gives you 4th. But in A, you're applying power to just solenoid 2 which is normally third gear, but I guess if the shifter is in (1-2) you get the 1/2 as before.
