i was thinking of doing the same thing but then i thought i would just save my money and build one my self with just the price of a filter and looking for some tubes that would fit
thats the first one i clicked but theres a boatload of sellers that have the same/similar setups for sale. i just built my own, with 3'' abs pipe and a 8" k&n cone filter, works great for only a 45 intake system. everyone has there own style they like, i would get caught up in the heat shield thing, they can handle a substancial amount of heat and where its postioned your gonna the best amount of cold air flow you can expect.
They sell K&N filters for the stock air filter intake box. It works exactly the same as far as filtering and is alot cheaper. I use mine mainly for filtering out long dry dusty Forest service roads that I use alot. When I use to change my "paper" filters I always saw dust layers inside my air intake tube, I don't see that anymore. The key though is to use the silicone sealent they give you in those leak prone areas.
I use Rusty's airtube ($29), K&N cone filter ($45) and use an air-raid throttle body spacer. It's a sweet combo, and even better with my Banks torque tube header. Very well aspirated, but I don't ford deep water so have never had to worry about the setup sucking in water. Seems like I'd get my sneakers wet if I was that deep anyways .
I got a fake K&N cone filter from AutoZone ($30) and put K&N oil on it, then I got a piece of 3" exhaust tube (free scrap from local exhaust shop) and flared one end out a little. The flared end fits nicely where the stock box used to hook up to the hose and the 3" end fit perfectly into the cone filter. I then cut the stock airbox to shield it from heat.
Billy
