- San Diego
i was just stating that was what someone mentioned. not that it was absolutely necessary when using them.
You can't double shear a TRE.
Well as far as the comparison goes: I'm looking at the Ballistic Fab steering kit which is $260 for all the heims, adapters, misalignment spacers and DOM. It uses 3/4" bolts in the knuckles and pitman arm, which are pretty damn strong. Gonna put hydro assist on it, which will take a lot of stress off the drag link, so running a single shear pitman arm heim won't be too bad after all.
Revival of old thread!
To the one who asked about tierod hitting the diff cover if you use an offset TRE it won't.
I have WJ knuckles and ordered these off set TRE's from RuffStuff. They were $36
http://www.ruffstuffspecialties.com/catalog/TREOFF.html
I've installed a few and always add a gusset at a Right Angle from the backside of the bracket to the axle tube.
a little hardinge chucker, or a clone?Machined down to fit, sorry miss the picture of them mounted up.
My tie rod hits the buckets way before full lock. How does yours not interfere?
