themangeraaad
- Halifax, MA
Ok, so the XJs drivers side front end is torn apart in the driveway right now to do a wheel bearing, so forgive if this is a duplicate post somewhere... but how does the unit reassemble... aka, where does the thrust washer go (looks like a bent washer) I checked the haynes and I didnt get anything out of it. I have the wheel bearing on there, then I have the washer, thrust washer, and hub nut. So does it reassemble wheel bearing / hub assembly then thrust washer then washer then nut or assembly then washer then thrust washer then nut?
