ParadiseXJ
- Paradise, CA 95969
picked up a multi tester and believe that the battery cables have a break in them,
Did you fix the cable yet??
Hit the starter with a pipe or a hammer a few times. Bet she'll fire right up. Strike it hard enough to free up sticky parts, but not hard enough to break it.
I don't know if I'd "smack it real hard" with a hammer. You could crack the starter case. Hit it, just don't break it.
is that a joke? maybe bad connection !!!
Hitting the starter is NOT a joke, it's an old mechanics trick. The carbon & crap inside the starter can build up and make the starter unreliable. Usually if THIS works your starter is on it's way out.
I think your closer to a resolution than you think. Clean ALL the connectors that have anything to do with the starting circuit, battery, grounds, starter. Take 'em off, make 'em all shiny clean with some sandpaper and put them back together...ALL of them, clean and tight.
Inspect the cables visually to see if there is corrosion outside and inside the battery cables. If there are any breaks and/or corrosion...replace them. There are new cables at any parts store, you may want upgraded cables, but you're just trying to get back on the road.
It's not rocket science, just old greasy corroded wires don't work so well even if you're sure the connectors are all good. If the starter and all the other components are testing fine, then it's either your battery or the wires...just sayin'.
