cj11
- Easton Pa.
97 Xj 4.0L auto tans
I have searched and nothing I found has anything to do with stalling with this code.
It has allways run fine no issues then all of a sudden this
The scan discription was no ccd received from ecm.
then it says explanation
ecm has not received any ccd messages from the aisin trans module within the ecm.
probable cause
1. ccd bus line open
2. failed ecm
It will turn over and run for acouple of seconds then stall again.After the scan flashed the code and it seems to run better did not stall but I did not want to drive to far and risk it stalling again.
Any info would be great need this to get to work and dont need to brake down on the highway.
probable cause
2. failed ecm
