Gold Cobra
- Woodland, WA
We just disconnected the cat and muffler. No change.
Just listened to your motor (youtube), you got to get back to basics. Make sure your basic setup is right then move on from there. Read Cruisers writeup on how to find number 1 TDC, recheck your firing order.
Have you had the timing chain off for any reason?
Could be something else, but it sure sounds like your initial setup is wrong. My best guess is back to basics and move on from there.
Where is your Rotor pointing when the motor is on the compression stroke, cylinder one and the timing marks are aligned? Some of the distributor caps actually have a "1" molded in the top, many of the newer ones don't.
clogged injectors have bit me in the past with the same symptoms
We indexed the dizzy like 3 times and also swapped coils.
I'd there anyway to check for a clogged cat? He's running a flowmaster so I'm sure that isn't clogged.
I'm with you, I've had my share of brain farts, but even getting one tooth off on the distributor, or a couple of spark plug cables crossed didn't make it run that bad.you have to be missing something stupid simple
One more wild ass guess, alternator?
Put a volt meter on stuff one at a time, sensors TPS, MAP, alternator.... and look for a spike when you goose the gas peddle, a spike that is way off,. or a missing spike that should be there. Try moving the harness like it would move when you goose the engine see if that make it miss.
We didn't meter meter anything while running because we couldn't keep it running long enough. When idling, it idles awesome, for about 20-30 seconds then will die. We swapped the ASD relay and the gauge on the dash is showing correct alt output.
Between the 5 people that have tinkered with this we have like 50 years experience with 4 liters. Not that that makes us experts, but it doesn't hurt. We just gave up and he's dropping it off at the night drop of a local shop right now.
Disconnect the O2 sensor and see if the problem is still there or gone. Drive it, give it the full test. The ECU will default open loop and if it runs great it is a problem in the O2 sensor system. Test the 12 volt supply wire to the O2 sensor heater. Test the continuity from the O2 sensor to the ECU on the 2 ECU-O2 sensor wires. Look for chaft wires on the O2 sensor line from exhaust or driveshaft encounters. A loose random contact wire short in the O2 wires will do it!!!!
