I have a 97 Jeep Cherokee 4.0
I had this issue awhile back and thought it had been fixed. Only when the engine is cold the jeep will cut out and jerk when driving it. It stopped before after I did a deep cleaning of the throttle body and IAC. Since buying the jeep in June i have replaced the following: plugs, wire and cap, TPS, CPS, MAP and 02 SENSOR. Could the cause of this issue be a bad IAC or something else? That is about the only sensor i haven't replaced but i have spent a lot of money fixing this since i bought it so don't want to buy something if that may not be the issue.
Any advice on what else could cause this?
Thanks
Thanks
