simspace
- Franklin, TN
Hi All,
I bought a 1991 4WD Jeep Cherokee Laredo. I need evacuate the A/C. However the Jeep does not appear to have, what I consider, normal low-side / high-side Schrader valve connectors. As seen in the pictures below (as described in the '91-'93 FSM) you will see the suction and discharge valves on the back of the compressor. Each valve appears to be covered and has a valve stem which needs a knob of some sort to operate the valve stem.
My question is how does this work? How does one evaporate and charge this systems with R12? What kind of hose connections are used to evacuate and charge the system? The rentals at AutoZone use the manual Schrader valve connectors that clip on.
The vehicle is not drivable at this time, so I would appreciate avoiding comments such as "bring it to a service center" or voicing EPA concerns. I need to understand how these valve work.
Thanks so much,
Chris.
Thanks so much,
Chris.
