Jeep 4.0L Engine Parts - HO and Renix models
twmart
If you need other 4.0L Engine parts let me know I may still have it, sensors etc. This is a partal list of what I have. I recently parted out a few early 90s Jeep Cherokees.
I am located in Broomfield, by 120th Ave and Federal.
1993 4.0L HO with a AX15 manual Transmission Parts
Harmonic Balancer $15.00
Power Steering Bracket $20.00
Alt Support Bracket (Steel Plate) $10.00
A/C Bracket with Idler $40.00
Water Pump Pulley $15.00
Steel Flywheel Cover Plate $10.00
Throttle Cable $15.00
Gas Pedel $10.00
Crossmember $20.00
Rubber Trans Mount $10.00
1990 4.0L Renix with a automatic AW4 Transmission Parts.
4.0L Flexplate $30.00
Alternator Bracket (aluminum) $20.00
Alternator Support Bracket (Steel) $15.00
Alternator $25.00
Starter $25.00
Intake with throttle Body and sensors $50.00
Steel Flexplate cover $10.00
Gas Pedel $10.00
ECM $50.00
AW-4 Control $10.00
Cruise Control module $20.00
CPS $10.00
Crossmember $20.00
Transmission Shifter $20.00
Transmission Shifter Cable $15.00
ALL PRICES ARE OBO
I just found more spare parts that I will not be needing. The following parts came off a 1997 4.0L with a automatic AW4 Transmission Parts.
PCM $50.00
Inside Fuse Panel $10.00
Do you still have the AC compressor mount bracket? The fan bearing wobbles in my 94 Jeep.
Here is how mine looks like.
Click to view full size photo.
It looks like mine has two pulleys on it. I have 94 Jeep CHerokee 4.0L
