- San Diego
my reason for not using weld in inserts is because the ones i found have a larger OD and i didnt want to take that much material off the knuckle. i wouldnt want to weld the split inserts unless i could spread them for a tight fit before welding. If i have a problem with them, i will probably just sell the dana 30 since i dont have a great alternative and build a 44 for more knuckle material and lock outs.
1. how much larger? the biggest I have seen are 7/8"s... that small amount won't make any difference.
2. I would weld the top in before you spread them, they would still be able to spread enough, and the weld on top will keep them in tight.
