I think this fits on this topic:
It was a Saturday afternoon, about a month ago just after an oil change at a quick stop place (that naturally says all levels are good) my check gauges light lit up, and the temp gauge was up JUST to the red, so I pulled over and stopped. After shutting the engine down and starting it back up the gauge was back to normal operating temp. It did it again before I got home, so I figure there is some sort of t-stat problem giving a false reading, if that was possible, and would bring it in on Monday. My dumb ass decided not to check the coolant level at this time because the oil change place "should" have. Call me stupid. Sunday, it did it again and it shuttered a little at a stop sign, so I drove enough to get out of the way and by that time the temp gauge pretty much pegged out, so I pulled over and had steam coming from the radiator. It was hauled, and the Jeep dealer said I had a leaky radiator, so it got replaced.
This past Saturday over lunch it did the same thing, so I pull over and stopped to see if the radiator was excessively hot, and noticed the coolant reservoir was low. I filled it up, and by the end of the day on my way home, the light came on again. I filled the reservoir up again, and by the time I got home, it was down to the add line again. I saw no antifreeze on my driveway, but then again it was raining so it could have been washed away. I filled it up this morning and drove it to work, and then topped it off again at lunch and drove it to the shop. They "put pressure on it" and didn't find any leaks.
Head gasket? Any other possiblities? Where would/could it be going if I don't see any on the ground? I don't see any returning to the reservoir (does it normally come back through the top line on the reservoir?) and it isn't up to the radiator cap when it is cold...
Sorry about the ignorance, but I like my jeep and want it to be fixed. Thanks!
