- Terra Firma
Yes, there should be a build code on the side of the block, adjacent to the distributor. The 6-digit code is a date. Look on the oil filter boss. Just behind the distributor there should be a plug with a recessed, square drive head. If there are component size codes, they will be stamped on the block just above that plug.xXJx said:how can i tell what size pistons i have? is there a number on the engine somewhere?
P = Rod journals 0.010 under
M = Main bearing journals 0.010 under
PM = Mains and rods 0.010 under
B = cylinder bores 0.010 over
C = cam bearings 0.010 under
