[email protected]
- Utah
Just like it says. Its it worth putting limited slip in a front axle at all?
i guess it depends on how hard you wheel if its worth it.
x2. After watching a Detroit Truetrac fail over and over, on easy desert hill-climbs, a real locking differential is a better choice, imo.
Even using the brakes to help modulate wheel spin did nothing except kill the momentum and still fail the climb.
Easy desert hill climbs should be...ummm...easy, even with open differentials. Any chance what you observed was an inexperienced driver or a bad Detroit TT, or was the TT being specifically tested?
Well this is my DD so locking the front is not an option. And LS sounds inafective. So I think I'll sit with open in the front, locked in the rear! Thanks for all you input!
i have a 242 t-case so a locker wasnt a option for the front axel.
Probably because he runs it on the roads in Full-Time mode.
It's even worse with the 242, never know where the power is going to end up....
What is wrong with driving around in 4x4 on the pavement? Is that not what the 242 is designed for running any road conditions?ARB doesnt allow you to only lock the front... If you locked only the rear and tried an obstacle, then turned around and locked only the front for that same obstacle, you would find it easier to accomplish with only the front locked.
Grab an aussie and lock the front. It will be invisible on the road in 2WD, you shouldnt drive around on pavement in 4WD anyways...
As far as the 242 goes. Why would you drive around on dry or even wet pavement in 4WD? What is the need?
I can see if your on a road that is dry 1 mile and snow covered the next... But even then I prefer having my front locked in in the snow, it helps pull the front end around corners when you lean on the gas.
The 242 uses some sort of clutch to seperate the front and back halves of the t case right?
Excessive slip on those clutches and they will wear out prematurely. I've only owned 1 XJ with the 242 and I dont think I ever used the full time option. If Im in 4WD its cause I need to be in 4WD. Why put excessive strain on parts when you dont necessarily need the feature?
Maybe its just my driving preference on the Full Time option... Non the less, I would still lock the front first.
