joe_peters
- Grants Pass, OryGun
Ok, will do. I need to clean the TB and IAC as well. See if that helps. Thanks again.
No problema; don't forget to post back and let us know.
I will. I always hate when people never post how they fixed something.
Will do. Thanks for all the help.
The Alt sure was some fun getting off with the Factory skid in the way. Makes me want to ditch the AC comp and run the Alt in its place.
Cleaned the TB and IAC and the idle is back to normal. It was dirty!! Makes me want to block off the EGR.
EGR isn't typically used during cold-start/open-loop. The design purpose of EGR is to reduce nitrogen oxide emissions by lowering combustion temps, which is achieved by recirculating some of the non-combustible (inert) gasses through the combustion chamber, which in turn allows less fuel for the lesser amounts of combustible gasses. All it really does is lower emissions. Conversely the cold-start/open-loop phase typically uses more fuel to encourage more post-ignition combustion, which helps to heat up the O2 sensor, which is what the computer is really waiting for. Sometimes a thermac valve on the air intake is used to recycle heat from the exhaust pipes into the intake, but I haven't seen that on any post-86 Cherokees.
hey joe, what is IAC on the throttle boby? not caught up on all my definitions, thanks
