fyrfytr1717
- Turlock, CA
I've seen these brought up in a few shock threads here on the JeepSpeed Prerunner Forum, but haven't heard of anyone using them successfully with a heim jointed shock. Will they work? Are the holes in the mounts (and therefore the supplied bolts) 1/2" diameter? Are the sleeves supplied for use with a bushing mounted shock? How about the width of the mount? I know there's a few different heim widths out there, but will these fit a Bilstein or an FOA?
I'd go with the JKS, but I don't like that they have to be unbolted from the body when you want to remove the shock for servicing. I'd like to remove the factory hardware (if I'm that lucky), install these, and never have to worry about those welded-in nuts again.http://www.ironrockoffroad.com/Merc...en=PROD&Store_Code=IROR&Product_Code=IR-SBPEK
