jjjjeremy
- Hollister, CA
I'm going to install the IRO Hack N Tap this weekend. Should I use the full drive shaft assembly with the double cardon joint in the front? I thought that you used double cardon joints when your driveshaft only has one bend, not two. I'm not planning on changing my pinion angle, so the pinion angle should stay parallel to the output shaft, making a double cardon joint inappropriate, right?
