rag
- central NJ
this is a wierd one;
i went wheeling today, wasnt too hard on the engine
at one point i thought i blew a headgasket or the actual head. i was blowing white smoke from my tailpipe and under the hood
when i say blowing smoke imagine a seafoam smoking type of deal only worse. much worse.
heres the thing, no powerloss, i was not beating the piss out of it, sometimes it would happen at isle, other times will at 1500rpm, no bucking, smelt sorta like when i seafoam a truck.
no apparent leaks other than my slightly leaky valve cover seal.
it happend 2 or 3 times for only several seconds. 20 seconds at the most then resumed to normal.
temps remained normal, good oil pressure, a steady 14volts to battery, not really off camber but it also happened on flat pavement
ive been driving it since and havent noticed anything new whatsoever.
coolant level is the same, oil levels are good, im completely stumped.
any ideas? is it time to stroke my extra block ahead of time and swap?
any input is greatly appreciated :compwork:
