cruiser54
- Prescott, Az
good info there Cruiser. Did you really think that the manifold upgrade was worth it without the upgraded head?
I think it would be much more beneficial to just swap an HO head and the HO manifolds, you would pick up that extra flow and the better manifolds. Personally, if I was going to be swapping manifolds I'd take the head off anyway and go do it on my workbench. I've not had to deal with mine yet, but it looks like it would be a PITA to do all of that in the engine bay.
I didn't upgrade the manifold, and no I don't think manifold swapping is worth it. These are inline sixes for crying out loud. . I port matched a Renix intake to an HO head. I don't see where much performance comes from the head anyway. MAYBE some at the top end? The point I'm trying to make is that the HO head is getting way too much undeserved credit for the horsepower increase when there were other things done to the engine at the same time which actually contributed more if you add them up. Get rid of the "crush spot" in the exhaust which restricts the downpipe by almost 40%. Put a much better flowing exhaust manifold on. Increase throttle body size from 52mm to 58mm. Use a better injection system. That's where the power came from. I have upgraded my 90 Renix in steps, but still have the original exhaust manifold. Got rid of the "crush spot". Then installed the 60mm throttle body. Then used 19# injectors. Very nice incremental improvements each time a mod was done. On my 88, I installed an HO, used the 60mm throttle body and 19# injectors. I also used the HO exhaust manifold which automatically gets rid of the "crush spot". The vehicles run about equal with the 88 having a slight advantage even though it's got 31" tires compared to stock on the 90.
