yossarian19
- Grass Valley, CA
Valve train turns over normally, no more fuel leakage (verify this. Never assume your "fix" really was a fix), turns over fine with plugs out, kicks with manifolds attached...
Are the plugs in good shape / firing normally? Getting signal correctly? I know you said it seems mechanical but can't hurt to check.
I suppose you *could* have a damaged rod... How about this...
Pull one plug at a time and spin the engine by hand, see what the results are. If it feels notably differnet with #6 missing than with #3, for instance, you'll get a good idea that you have jacked up compression / rotation in #6.
If it were me, I'd want to be *really* sure before I started tearing down the head on a diagnostic mission.
