impetus-93xj
- Burnaby B.C
do any of you know if any of those injecter cleaners out there work or are the bad or what?
Cherokeekid88 said:I use lucas, and i swear by it
Another draw back of your short distance driving. As far as injector cleaners go, I've never tried lucas, but Seafoam and if you're on a bit more of a budget, Chevron Techron both do good. Just added some seafoam to my tank on this last fill up. Search around on here for that stuff, you can add it to your intake and it's been known to make a world of difference on older XJ's, have yet to run it through the intake on mine.impetus-93xj said:thats good cuz i have realy bad fuel milage....is this normal with these xjs
JNickel101 said:you can use acetone too....but that BG44K is strong enough you only have to use it once every 10k miles or so....
there's an active thread about "Acetone" and its pretty damn big...lots of good info/experiences in there.
RichP said:I wondered about using acetone, without digging thru that thread what was the amount of acetone to use to clean on a 20 gallon tank. My suspicion is that acetone is what the cleaners use as an active ingredient but they, Chevron, Valvoline, etc won't tell you, it's 'proprietary' [my ass, they charge a fortune for that stuff, would love to know what the mix is], acetone is cheap.
