89CherokeePioneer
- Massachusetts
89 Cherokee 4.0 AW4, 231
I want to setup relay's for a couple of the dash accessories. I do NOT like the way the blower motor affects the dash voltage and the IP lights. The cigarette lighter also dims them a touch too..
Does anyone have a ignition switch wiring diagram for the 89 Cherokee?
My plan, or atleast one. Set it up so that when I flip the key over to run, the ignition switch triggers a relay which is wired to the positive lead on the starter relay, then wired to the climate control panel. Should take a load off the ignition switch no? Seem's like these share a common source of power.
