akennedy99
- Chelmsford, MA
So I was futzing around with the wiring harness that goes into the ignition switch and now I am having a starting problem.
When I turn the key to:
-ACC: Nothing Goes on
-Lock: Nothing
-ON: Nothing
-START: Lights go on like on should be.
-Back to ON: Lights stay the same
There is no spring back though, like there was before when you turn on the key. Does the Key lock cylinder or Ignition switch do the spring back?
I have always been able to pull the key out at any of the above stages without effecting the state of the vehicle.
Did I mess up the Ignition Switch or Key Lock Cylinder?
Thanks!
-Lock: Nothing
-ON: Nothing
Thanks!
