OK, I found my ignition switch, and uninstalled it just fine. It is identical to the one Schucks sold me.
I reinstalled it, per the Haines manual instructions, and now it will not crank!! I have a 1990 4.0 XJ AW4 w/ tilt wheel. I adjusted the hole on the switch so where the rod sticks in was all the way to the right hand side, if you're facing the driver side door. The ignition was in the accessory position, just like the haines manual said.
I have non-switched power, but do not have switched power. WTF is wrong here? If I wiggle the switch on the two screws, I can sometimes get my radio to come on, but when I turn the key forward to start, nothing happens. No cranking or clicking.
It is getting dark soon (15 minutes) and I have to be somewhere at 8AM tomorrow morning.
What am I doing wrong?
