Idle Problem
Trailbst
Westerly, RI
87 4.0L Auto
I got this XJ for free.
It runs, it idled, then the idle would creep up, and up.
So I replaced the Throttle Position Sensor today.
When I restarted the Jeep, the idle immediately shot up to 3000 RPM.
What else could cause this?? Did I know off a vacuum hose?? Could that be the cause??
All help will be appreciated.
Thanks.
Erik
TPS Adjustable up to 1990
You don't mention adjusting it to get the output in spec- has to be 82% of input voltage if you have an auto tranny, at idle (throttle closed). Input should be about 4.8 to 5.0 volts. Back-probe the connector to test. 4xBob
I guess it's not as simple as just plugging it in.
Time to get a new Haynes or Chiltons for it.
How do you check the output??
Thanks in advance.
Erik
