emr1101
- Raleigh, NC
Ive gotu about 7-8" of lift, with drop brackets, RE 4.5" upper arms (bolt and tabs on axle end, worn out rubber bushing on frame end, no vibes from it though) and just about brand new lower super flex, adjustable control arms. They have fresh bushings on the frame end and good superflex joints on the axle end. I was looking at rock krawlers 3 link LA upgrade, looks like something like that would be easy to fab up if you just had a buddy with a set and just built yourself some arms and then for the brackets either make your own (might be kinda hard) or even just buy them separatly from Rock Krawler.
Then I got to thinkin, for the LCAs of the RK 3 link cant i maybe just get like an few inches of threaded tubing of the correct size to put in as a center piece extension for my LCAs and make them into long arms? Only down side is they would have to have a good amount of threading so id have to be careful in designing them, and they would need to have their lock nuts on extremely tight, as you can image what would happen if they were loose. In addition to that, while that super flex joint would last a while, who knows about that bushing (maybe when it wears out replace it with a kevlar heim, but for now i think it might offer some good driveability advantages). Does this seem safe? Or even feasible? Im thinkin then run a double kevlar heim ended upper control arm. If i had my hands on a Rock Krawler 3 link kit it may be possible to fab up a copy of the brackets, maybe not even a copy but just measurements of the arms and then see the locations of where the mounts would go.
Anyone tried this?
Anyone tried this?
