the reason they're only showing cv is that i'm fairly sure your year used cv shafts, not u joints... i know the early cherokees did. the one with the u joint is likely an upgraded replacement to a later junkyard axle.
get one from any later year, the disco was used through 1990, there are quite a few on ebay at the moment.
You could always eliminate the disco and go to 1 piece shafts too.
