JeepCherokeeGuy99
- New Bern, NC
check engine is on...
Always threw the code for the coolant sensor (i replaced it and it never went off before the hydrolocking)
now i've got codes for the TPS and the IAC and i think a couple others. I am pretty sure that when one throws it can set off the others too though. The TPS potentiometer is hanging outside the throttle so i don;t see how water going through the intake could break it.
fix the problems that the codes are telling you and your jeep will run fine. FYI electricity hates water. The TPS is bad for sure. Pull all the plugs to the sensors and let them dry. Try plugging them back in and clear all the codes. Whatever codes that pop back up will need to be replaced. Also, check all your Maxi-Fuses
