30 spline is 30 spline. It doesnt cost anymore to buy a 30 spline arb/shafts for your dana 30 than it does to buy 27 spline arb/shafts. Oh wait, the waggy 44 doesnt HAVE 30 spline outer shafts, they are only 19 spline. And the same u-joint. Stronger carrier? go ahead, break a couple of carriers and post up some pics. And the waggy 44 ring gear is indeed bigger - but since its low pinion and you are on the coast side, it has a smaller contact patch than a 30 would.. and I've never seen a trussed 30 bend, how much stronger does it really need to be?
The only thing a waggy 44 gets you over a 30 is bigger ball joints, but not very much bigger, and at the cost of worse driveline angles, weaker stubs, and a ton of fabrication.
Yes, but the JK 44, which is what was suggested here, has 32 spline stubs, full crossover steering, bigger balljoints..
So does alloy-usa, superior, etc. They use dana 60 u-joints, not 760's, and require going to 1 ton outers - an MAJOR project.
Bring your 44. I'll put it up against my 30 any day of the week, and you *WILL* break first, assuming of course you havent gone 35 spline with 60 outers - but maybe even then.
Go learn about current Rubi 44's, and then come back to play.
