Jonner
- Charlotte, NC
I'm curious to see if the OP figure out the problem.
I've had a fairly high-pitched wauhwauhwauhwauhwauhwauh (lower-pitched than a squeal) noise that started 6 months ago. It would only show when cold, and typically only lasted a minute. The pitch only changed slightly when revving the engine but not much, and was definately coming from the passenger side of the engine bay.
Yesterday night, the noise lasted 5 minutes in 10 degree weather with the engine cold, so the problem is getting worse. I didn't have a stethoscope of any kind, but when I put my hand on the distributor I felt vibration and the noise seemed to be coming from the distributor (although the vibration could have been normal for a cold engine).
My hunch is that a bearing NEAR or IN the distributor is going out, but haven't looked into enough to know where the oil pump, etc. is?
