http://www.mcmaster.com/#24175K43 is the part number. You want the vinyl edge trim, dual gripping edge in 5/32" if the link doesn't show up. The part MC supplies is actually made by Trim-Lok, which seems to be the pinnacle for edge trim.
As for the shackle relocators - it's actually very straightforward. If you have a hitch, take it off in advance, or be prepared to take it off for installation. Your bumper must also come off, which I found to be the biggest pain in the ass over everything else. This might not be totally necessary? But I found it made the entire job a TON smoother. After everything is put together, it takes a little while to figure out what setting (mounting holes) to use for the shackles themselves. I had to adjust them 3 times before I found the perfect combination of shackle length/lift height/angle. The nutstrip on the passenger side must be removed if you want to put some better mounts inside the frame rail. I used 3, 1/2" grade 8 bolts with washers and dropped them through the holes after taking out the nutstrip. These brackets really do make a world of diffenence.
Total install time was about 3.5 hours, over the span of 3 nights. First night I took off the bumper and drilled out the rivets for the nutstrip, second night I installed the actual brackets, third night I put the finishing adjustments on the shackles and put the bumper and ends back on.
The RC control arm drop brackets took about the same time, in one night, and had exponentially more cussing, tire kicking, and headache asprin involved.
