I also have power everything and I did the mod with ease. You just have to unplug everything in the on and off process and thats more of a pain then the door removal itself.
You cut the bottom flange on the hinges off. This will allow you to slip the door on an off like Wrongler doors. Once youve cut the bottom flange off the pin will be exposed. If you wanna keep it cut it down a bit so its easier to get the doors over the hinge assembly. Or if you wanna make it easier just knock the pin out and do a bolt/pin setup that you can remove. Its what I did and I just open the doors and remove the pin, door slides right out. Much easier then hitting that set pin in the hole everytime. Seeing how the doors weight in excess of 80lbs this is a uch easier setup.
Heres a pic of what Im talking about...
