Wa Woody said:
I did a quick search here and found a lot of good info on the WJ brake upgrade, when I have time I'll read through it all. In the mean time, do you know of any good tech write-ups on doing the WJ brake upgrades, especially if they're using the Warn 5 X 5.5" kit which I'm also using.
We are getting way off topic of this thread but the "short" story is:
- 86 CJ7 rotor uncut
- Warn supplied spacer does not go between rotor and hub assembly
- caliper bosses on knuckles must be machined to realign caliper to rotor (was 3/16" on my knuckles - measure before cutting)
- spacer obtained from JKS is welded to knuckle as per the standard WJ knuckle swap procedure.
The above ONLY applies for the 5 on 5.5" kit. 5 on 4.5" kit is a different procedure.
If I was going to do it again I'd probably try Scout II rotors instead. the rotors on the bench across the shop appear to have a slightly shallower hat and they appear larger (more thermal mass). Wish I had noticed that before pounding the studs into the rotor/hub. It also appears that the shoulders of the supplied WARN studs may interfere with the wheel seating on the hub ever so slightly depending on what wheel you are running (Cragar S8s in my case interfere). I had some Sidekick rotors machined down to make a slightly thicker spacer than the WARN supplied one just in case. Adds about ~1/16 to the spacer thickness which looks to be about right.
jksmfg.com used to have copies of Mark Hinkley's XJ specific WJ knuckle swap write ups from their pages but I haven't found an obvious link to the pages since JKS revamped their site.
For more WJ info I suggest some googling and reading/digesting the stuff you found here and then start a new thread on the site if required. So far, in my experience it is as easy as the docs floating around lead you to believe. Take that with a grain of salt as the axle is still sitting on the bench in a "mostly done" state.
There might be a half dozen or so people that I've seen on this site that have done the swap. The only tricky part in my opinion is machining the knuckles but you will be letting a machinist do that with the parts in hand so no big deal. Get them to do the spacer welding too if it makes you feel more comfortable.
Getting really close to "lift day" now...
