PhotographerMike
- Whittier, CA 10 Mi. east of L.A.
1) My original "bad" sensor read correctly when cold but lost all resistance when warmed up. I popped it in a 200 degree oven, no resistance, cooled it off, just fine.
2) So I got a new one from NAPA, cut the 5-90 slots, installed it, no good! Returned for exchange (had my meter to prove it was bad if necessary), no problem with returning the modified part.
3) You might only need flex for the last few inches at the upper bolt. I used 3 extensions to get close and finally a 12 in. "wobble" extension, 3 inch ext. and u-joint short socket. You start feeding the extensions from behind the top of transfer case. My lower bolt came out with a stubby rachet worked from the front of the trans. Don't forget to grease the sockets.
