Dr. Dyno
- Al Ain, UAE
Come on, there must be more than seven strokers out there. How about some more responses?
Dr. Dyno said:I run Ford 24lb injectors, stock 39psi regulator, and MAP adjuster set at 5.15v (stock voltage is 5.04v). Only fuel available to me is 91 octane with MTBE.
The combination of Flowkooler high-flow water pump, Robertshaw 180* t'stat, good factory two-row radiator, and cold air intake ensure that the engine runs cool and stays ping-free even on a 115*F summer day. Keeping the cylinder head and intake air temps. down are critical elements in preventing detonation.
Bender said:Those of you that shimmed your rockers....what thickness shims did you use?
I milled .010" off the block and used the stock pushrods with the stock rockers and moper performance valve springs...the preload seems to be within spec......or so the machine shop that did the assembly told me. Like was mentioned earlier i get a valve train noise when warm....thinking of shimming the rockers to see if it helps.
