tchase
- Nova Scotia, Canada
lapisxj said:One of the best parking brakes is a line lock. Just mash the brakes and flip the switch and it won't go anywhere. Look up part # SBR-LL on summit racing's website. For $40 and a couple of adapters and a switch, you can't beat it and a mechanical E-brake won't even touch this especially with larger than factory tires.
I strongly disagree. I've had the fortune of experiencing a loss of hydraulic pressure on a steep hill while wheeling with no mechanical e-brake to fall back on. Not Fun. LIne locks still rely on you having a functioning hydraulic system. I've also snapped a rear pinion on my 2wd MJ on a steep hill on the street, had to rely on the passenger holding the vehicle with the hydraulic brakes while I crawled under to remove the shaft so I could back down the hill. They are called emergency brakes for a reason and I think all vehicles should be equipped with some means of stopping/holding the vehicle which is seperate from both the drivetrain and the hydraulic brakes (ie wheel mounted stock type parking brake).
just my $0.02 worth.
Tony
