MoFo said:I finally got the RMS punched out and replaced, plus all the other stuff I discovered while in there, timing set, front seal, HB.
Now I am trying to stick the gasket up to the block, so I can position the pan. I have the 1 piece Felpro gasket. With other engines, I have had success useing Permatex #97 Super High Tack Gasket Sealant to hold it to the block. The gasket won't stick to this stuff. I have tried letting it dry various lengths of time, and it just won't stick. I also tried the 5-90 trick of SBC valve cover studs, but the gasket has metal sleves at the bolt holes and it just falls right off.
BTW, this is a 1987 4.0 liter.
I have scraped the block surface and re-applied sealer 4 or 5 times now. Any recommendations would be greatly appreciated.
Bread ties will be your friend. Use a few of them to hold the gasket to the pan, put pan in place, start a few studs, cut/remove bread ties, and button her up. Works like a charm. Good luck. :wave:
