goodburbon
- Westcliffe Colorado.
I went to the exhaust shop yesterday to have them patch a hole and re-attach a hanger. While I was there the tech pointed out that my exhaust was getting waaaaay too hot, and noted that the pipe was blued from the engine to the muffler.
The engine temps have been high lately, I can't run the AC in traffic or the engine will overheat. I did some searching and was beginning to think that I had a leaky intake manifold gasket and was running lean. But my rear axle is covered in soot, and my exhaust is extra hot, which I think indicates a rich condition.
Relevant information.
97', 4.0, cone air filter, constant bore stock TB, TB spacer, Banks header, oxy sensor<1year old, 3 inch exhaust from the header back. New 3" magnaflow cat installed with 3" exhaust. 13-15 MPG on 33's with 4.10's (rich?). 180* thermostat, Jet stage 2 Chip, using 93 octane (jet chip requires 91). last codes thrown were for incorrect purge system flow, but none in the last 6 weeks. It has been running around 200-220* since ambient temps have been over 90*F.
Any thoughts as to cause and solution?
