The horn has never worked correctly in my jeep since I have owned it. I was never able to make it horn by pressing the button but it would honk from time to time when I would turn. I have disconnected the horn but when I turn I can hear an arcing sound coming from down by the fuse panel. Also, I can now hear this same sound when i wiggle the blinker switch. I also noticed that my wipers seem to move at about the same speed regardless if where they are set. I guessing this is a short in the column or a bad relay? Where should a look for a short? What else could be wrong?
Has anyone replaced the entire fuse panel? Mine has seen some better days
